The heating works fine and when the heating is on the hot water is fine too. But when the heating is off there is no hot water. I was told it might be the diaphram part number BI1011103 "Central heating pressure switch membrane" which I replaced but it made no difference.
So, here's what happens:-
When I open the hot tap I can hear a whirling noise (fan?) but the burners do not fire up and when I close the hot tap the green light on the front of the boiler flashes rapidly for about 5 seconds and then slows to normal pulse. Is this an indication of something at fault?
I've taken the front cover off and used a cocktail stick to make the connection in the Microswitch (i.e. the pin does come out when the hot tap opens but maybe not comming out fully?) and this results in the burners firing-up and the water temperature from the hot tap fluctuates from luke warm to cold.
Could there be a problem with the PCB or the temp probe or what else?
I hope somebody can help me
Oh, the boiler is: Biasi Riva Compact M90E 32S, fitted approx 7 years ago
