Biasi HE 32
30 Apr 2008
Wiltshire
Is the Biasi HE 32 plus any good as a boiler or is it a waste of time? A lot of plumbers i have called in my area have rubbished the make of boiler although i did not know if it's because they prefer to supply and fit a boiler rather than just fit.
Any replies greatfully received
They are not the best from previous experience but what ever floats your boat.
Worcester Bosch, vaillant, viessmann are a few of the best brands
A cheaper boiler fitted to a clean system and commissioned correctly, will usually outlast a top spec boiler such as a Vaillant or WB that has been fitted by a 'cowboy'.
Biasi are making a lot more of the other makes boilers out there than you realise.
The boiler will be fitted to a basically new system. Everything apart from the inlet pipe from the street will be new.
As long as it is flushed with x300 then filled adding x100 and commissioned as per MIs I don't think you should have many problems.
I believe the new Biasi has one of the lowest failure rates under warranty at present. Less than 1% I think was posted here a while back.
There is a lot of 'snobbery' when it comes to boiler makes and most of us, myself included, are guilty of this :oops:
Would this explain the comments of take the boiler back i got then? :? A couple of guys who i know to be good from other people have said they would install the boiler no problems at all.
