Hello,
can anybody help.
I have a three year old combi as above.
A gradually worsening fault over the past few months has been sporadic non availability of DHW.
Last week it got much worse so I got a CH engineer in. He found that the diaphragm was apparently operating, pushing the pin out when the hot tap was opened and operating the micro switch, which in turn started up the heating sequence, all hunky dory. EXCEPT, sometimes even while the hot tap is still open and water sounds as if it flowing thro the valve, the pin goes back in and of course the micro switch does as it is told and aborts the heating sequence. The engineer thought that possibly the diaphragm although not showing any visible damage, may have been dicky, so he fitted a new one just to be sure and took three tenners off me because when he left the system seemed to be working properly.
Of course before he reached the end of the road it had reverted to its previous form and now hardly works at all when the DHW is demanded.
Any advice would be appreciated because the dreaded call out charge makes speculative diagnosis rather unattractive especially in these credit crunched times.
cheers and regards to all the DIYnot community.![Question :?: :?:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
can anybody help.
