Biasi m90e 24s Boiler works intermittently some times it fires and runs fine but then will stop running once the stat has been satisfied and calls for heat again or run the hot tap, pump runs fan runs, you can here the air pressure switch and you can see the pin activate the micro switch just won't ignite ( no spark ), any ideas would be helpful.
James
James
