Biasi M90E 24S
29 Oct 2009
Hi
I have a M90e 24S which works fine on the hot water side but for the central heating , fires up for a few seconds then shuts down. This is only just started happening. Any suggestions
If it worked properly a short while ago then either the diverter valve is jammed or failed, the DHW demand switch is jammed on, a sensor has failed or rarely the PCB has failed.
You may need to call a gas engineer unless you have the skills to try to repair it yourself.
