Biasi M90E 32s with Honeywell cm921
18 Apr 2011
Lancashire
The boiler is five years old and is leaking at the gland and the main green light pulses in 2 second intervals.
The boiler state is that whilst DHW is intermitant and there is no CH. After removing the clock plug from the pcb the ch sarts to work fine but when it is pluged back in ch stops working.
I am going to replace the the gland and whilst replacing the glad is there any other servicable part that would be worth replacing? (diaphram/divertor valve kit)
Can someone advise how to access diagnostic mode on this boiler and is there any advice on the ch fault? Is it the dip switches?
When dip switch 1 is switched the main green light pulses quickly and other green and red light a on.
When dip switch 3 is switched the main green light is on and the red light pulses 1 per second and the other green light is off
Any help on the matter is greatly appreciated
Thanks in advance
Grover
There are two glands on this model.
You clearly seem to fiddle with anything when you dont know what they are for.
I have twice previously described how to put these boilers permanently into diagnostic mode. You can search for that.
For a few secs put DIP 4 down and then up.
Tony
I have put my boiler in permanently Diagnostic mode by moving one of the links on the 9 pin jumper line so that now joins 6-7 and also made two holes at the front to monitor the LEDs.
The boiler's main LED flashes 1 sec on 1 sec off but no DHW or CH, but I remove the on board plug from thr PCB the boiler CH only works.
Unfortunately, I am no wiser as the main LED only flashes 1 sec on and 1 sec off in CH mode and 4 sec off and on for a very shoet time, in DHW.
Grover
