Hi Forum.. sorry long post but want to get the facts down..
had a Biasi M96.29SM/C fitted 3 years ago.. about 2 weeks ago we noticed that when in the shower it was going hot, cold, hot, cold etc every 20/30 seconds.. Was due to go to spain for a week so left it till I come back to sort..
Wednesday 8th
When I returned we tried the shower again and this time it just went hot for a bit then cold.. looked at the boiler and it had the lock out light flashing and had to press the reset button to get things going again... Called in a heating engineer..
Thursday 9th
when he turned up (wife was there not me) he spent an hour looking over it before saying it was the Overheat Thermostat ... he removed it and cleaned it in some way (looks like he took a scraper to it) .. when he replaced it the boiler was totaly dead so he went and got a new one.. Once he fitted this new part the boiler was "working" again back to its original fault of the lock out light.. He then spent another 1 hour 30 minutes looking at the boiler and then said the PCB is "faulty".. bill so far is £52 call out plus 5X £32 per half hour + 11.72 for new part + vat (not paid him anything yet) he then wants another 200 quid +vat to supply and fit PCB. total 423+vat
Just wanted hot water back so said fine if thats the issue then just get it sorted.. He phoned for a new PCB but (luckily I think) it was out of stock... Said he will order it and it and fit Monday...
Friday 10th
He had left his meter at my house.. So came round for it, while he was here he wanted "one more look before deciding it was a PCB issue") He said he rang biasi last night and that they said it was doubtful it was PCB as termpreture was going up to 90 degrees and then cutting out and therefore was a heat exchanger issue.. He said he thought it was a PCB issue as he had seen the gas pressure too high blow them (is this a load of bull? and then said my pressure was on the lower scale of normal but OK so thought that was the issue orignally) He wants to come back Monday and "just" charge me on the 30 minute rate to try and clean it... No doubt he has charged me another 32 pounds for tellijng me that!!!
Ok.. I'm not shy of DIY and had a good old google (found this forum) .. I first thought it was membrane gone but can see that the micro switch is being pressed against and stays pressed no problem. The next most common issue I saw was the heat exchanger being clogged.. This was 10 minutes on these forum that this guy expects me to pay 223+vat so far to get to the same conclusion..
I'm very tempted to call him tomorrow and tell him to not bother coming back as have lost total confidence in him.. Im sure I'm looking at another hour of labour atleast for him to try and clean it out.. I think I might just aswell go and buy a new exchanger and fit it myself..
OK questions..
Does what this "engineer" has performed so far warrant paying £223+vat.. From what I have seen he has replaced a part that may of been near to end of life but was working.. and spent 2.5 hours getting no nearer to a solution before calling biasi to put him straight.. I'm tempted to tell him to bolt and give him a bit of cash for his troubles, but I'm sure the law is on his side
If I do this myself .. can I try cleaning it myself ? If so with what? i take it is limescalled up? or just go for a new part?
If I decide to get someone else in what is the best way of finding a good engineer in southend, essex?
Just glad that PCB wasn't in stock as that would be another 200 pound thrown down the drain
Thanks in appreciation..
Neil.
Wednesday 8th
Thursday 9th
Friday 10th
OK questions..
Neil.
