The model is a Biasi M90F 24S.
Problem:The boiler cuts out and requires manual reset button. It then overheats and repeats. The DHW is fine and doesn't cause tripping.
Thought it was a circulation problem. So a powerflush was done, but it hasn't solved the problem. Looked at the pump and its weak, running at about 40 (ohm) so thinking of replacing pump? As first option Yes/ No?
or
Is it more likely the PCB that needs to be changed? Second option.
In addition the piping looks like it needs upgrading as it goes from 22m to 15m, not sure if this really matters?
Best next step would be welcome. Thanks..
or
