we\\\'ve had a problem with this boiler for well over a year now, and nobody seems to be able to fix it!!
The problem is the lockout light. Some days it will NOT reset. I press the reset button, the fan runs, the ignition starts, but the boiler locks out before it fires. This may happen all day for days, but then it will be fine for months!! Everytime i call someone out, they charge the earth to \\\'clean it out\\\' or \\\'change the pressure switch\\\' etc... but a day later, it locks out again, usually when it\\\'s freezing!
The only other thing you have to go on, is it seems to go off alot when the hot water tap is turned on. You can reset it and the water will heat, but the first call for water seems to trip it!
I really hope there is someone out there that can shed some light on this now very annoying problem.
