Hi
I have a Biasi Riva Compact m90e 28s.
On many occasions, when the hot water is called for it runs
cold and the boiler doesn't fire up.
If the heating is on hot water runs fine. Also if the
heating is activated and turned off even after a
second then hot water will also work ok.
The green indicator on the control panel also
flashes rapidly with no lock out indicator (when
the water is not working).
Would it be diverter valve or flow switch for DHW??
Any ideas?
Cheers
Peter
Any ideas?
Cheers
Peter
