Hi guy's,
I'll try to explain this as best possible.
Installed in 2009 and never an issue with it other than the aav had to be replaced about a year ago.
Anyway, the issue is with the flow temp to the rads.
In the colder weather we've always used a flow of around 70c, as we know that the rad in the living room especially is undersized, or the living room should have had one more rad.
Fired up the heating the other evening, and the flow temp is not behaving as it used to. It used to pretty much have a consistent flow of around 70.
Now it runs up to a 70 flow, then just drops to 50, goes back up to 70 and the cycle repeats. So, an average flow temp of 60.
It's as if the gas valve is not modulating, or a problem with the pcb?
Thanks in advance.
Thanks in advance.
