Sorry for adding to the many condensing boiler posts, but I'm a little puzzled by the logic behind the efficiency arguments.
I've read about the advised flow return temps for condensing mode, over sizing rads that some people do, temperature differentials on flow return, but don't these requirements or advice offset the efficiency gains somewhat? Oversizing rads obviously incurs some extra upfront expense as well as other possible problems, but what about return temps and the energy required to increase a possibly artificially low return temp up to the flow temp. For example, if a hypothetical system can deliver a return temp that is the same as the flow at, e.g. 70C, then losses in the boiler aside, would it not be better to keep that setup than drop the return temp to 50C just so that condensing can take place, and then use more energy to raise the return temp up to 70. If that is a correct supposition, then what if the return temp was 65C? Might that use less energy to raise to 70C than from 50C to 70C, even with the benefit of heat from the condensate. etc.
Further, how can we achieve the low return? If flow is 70C, all rads are getting hot evenly, there's minimal temperature drop across the rads, and the final return is 60C. Is it really better to create drops in temperature across the rads, giving reduced heat output and therefore potentially a longer running time of the boiler to create a lower return temp, or is the loss of potential output compensated for by having a larger rad that gives similar output from its larger surface area?
Our actual system is an ideal logic+ combi with electric UFH as well, and a network of dallas 1-wire temp sensors around the house with a couple strapped to the main flow and return to monitor that. The system is balanced sufficiently so that all rads (myson decors) get hot, but the surface temp drop from one side to the other is nothing like 10C or more, which to me seems fine as that's surely more heat output. The return temp on the pipe is around 55 with flow at nearly 63 (boiler claims 67), so maybe that's perfect, though the return can rise higher.
So I'm just puzzled about how things really balance out when all factors are taken into account with combis, and that while they are more efficient in themselves, does that really translate into more efficiency in practice?
