Biasi Riva m90 24s DHW problem
2 Jan 2012
Avon
Hi everyone,
This is my first post apologies if it seems like ground that has been covered, but I have searched the forums and can't quite find a solution...
I have a problem - I can get hot water if I restrict my flow to approx. 3l/min but when I open the hot tap fully open [7 l/min] the water is at best lukewarm... This is a real problem when running a bath as it takes 20 mins to fill a lukewarm bath.
The temp on the boiler reads 65 deg C with the bath tap on full, but the water coming out of the tap is only 35 deg C. I f I restrict the flow to 3l/min I get a healthy 47 deg C out of the bath hot tap [the temp on the boiler now reads just above 60 deg C. Distance is approx 6m.
I have gathered from the forums that this could be a number of problems, but I wondered if my symptoms pointed to something more specific...
Any advice would be much appreciated! Thanks in advance...
Kind regards,
Nick[/url][/quote]
Since the boiler isn't getting hot enough my guess would
be the diverter valve isn't diverting fully to hot water.
Thanks for the reply... is there anything I can do to test it out? Looking at the manual it looks like a complex job, any tips...?
Thanks in advance,
Nick
This model has a diagphram and it could be that ?
Turn the central heating on and run the hot tap at the same time and see if it works ok.If so it's a 30min job and the last one i did cost about £9.
When the heating hasn't been on and flow is cold, turn on the hot water.
Feel the flow pipe and see if I gets hot. If it does then diverter valve is faulty.
This boiler has a Hall effect flow sensor and a motor driven diverter valve!
How would Bob deal with that?
