I had this combi boiler fitted to my 1 bed house, fitted about 3 years ago.
Lately DHW heating has reduced in efficiency. When I first got the boiler, if I turned on the hot water tap fully for the bath, I had hot water hot enough that it was only possible to hold my hand under it for a second or two.
Now, I have to substantially reduce the flow by turning the tap to the halfway position in order to get the really hot water.
I have carried out a thorough investigation of the boiler and carried out all service tasks (bar checking gas pressure) and everything seems to be working ok. I have also followed through the fault finding chart in the manual and all seems ok.
I just measured the flow rate from the hot tap at full power which is approx 9L/min. Boiler flow rates are quoted at 9.8L/min for 35 deg rise and 11.4l/min for 30 deg rise so I am within the spec.
Any ideas??
Any ideas??
