BIASI TIMER CLOCK FAULT
29 Apr 2012
Cumbria
MODEL-BIASI GARDA PLUS HE M110.32SM/E THE TIMER CLOCK KEEPS RESETTING TO 12.00[FLASHING] I RESETT THE TIMER-IT CAN LAST A FEW DAYS THEN GOES BACK TO 12.OO[FLASHING].THERE DOES NOT SEEM TO BE ANY FAULT LIGHTS SHOWING-WILL IT BE THE CLOCK OR COULD IT BE A PCB FAULT -ANY HELP GREATFULLY ACCEPTED :?:
Have you used the tiny reset hole?
Is the mains power to the boiler being interrupted?
Are the plugs on each end of the communication cable fully inserted? Note the clock end is not keyed!
thanks for this-i did reset-the power hasnt been interupted but it is worth checking these connections before buying a £65 timer clock-THANKS A MILLION ILL KEEP YOU POSTED-DRH
Since it will need to be opened to replace the clock you might as well check the connections first.
