biasi combi boiler working normal for HW but only fires up for a few seconds on CH..(enough to heat the flow but no long enough to return)
Pump is still turning, the pin on the diverter valve is moving ok when hot tap is opened
Looking through the manuals fault finding section it points out that it is either the thermistors taking a false reading and cutting off the heating or it is the PCB. I have went and got the new thermistors (£20 for the 2) and am going to try this 1st as It is expensive to get a new board and thought it would be worth it to try the cheapest option 1st especially if the manual says it is one of these two...
Can anyone advise me on what to do if the temp probes dont fix the problem how could i tell if it was the board?
or even the 3 port diverter valve(in some way check it ) the manual doesnt mention it possibly being the diverter valve though..
