Bitumen DPM + self levelling compound, will it stick?
27 Jul 2013
London
Hi I've tried to find the answer to this everywhere but seem to get conflicting views.
I have an old concrete subfloor which is a little damp so have covered with Wickes liquid dpm which is bitumen-based. But I now need to level this before tiling but don't have much height to play with - 10-12mm.
Can I prime the bitumen and then pour on a latex slc? Will it stick?
If not is the another way of levelling on top of the bitumen before tiling with ceramic tiles?
Thanks for any help.
I think I've found the answer. Ardex Arditex NA. Does anyone have any experience of using this? Thanks
Thanks for the recommendation. Just put the NA down, how long should I leave it before putting an f75 dpm on top? The NA it about 8mm at its deepest. Thanks.
Thanks for that! It just wasn't entirely clear. I'll give them a call.
Further to this - I’ve just put Black Jack 108 DPM down on a screeded concrete floor. Now looking to self-level…
I’ve bought some Screwfix own SLC but have read conflicting information about it adhering to a bitumen emulsion.
Does anyone know if it’ll stick?
Do I need to prime first?
Do I need to blast it with sharp sand?
Failing any info on the Screwfix offering, will Ardex Arditex NA go down without primer, or do I need to put some SBR down first?
Cheers
Don't forget to paint the DPM up the walls as well at least as high as the expected thickness of the final floor. I'd put 2 coats down, a light dusting of sand on second coat won't go amiss - not sure about sharp sand as you don't want to pierce the DPM.
Evening.
Yep I’ve painted the DPM up the walls, higher than the FFL.
Do you mean two coats of primer? Or DPM? It’s had two coats of DPM (on top of a watered-down coat).
I’d read that sand scattered over the drying final-coat of DPM helped create a key for the SLC, but may have got it wrong with it being sharp sand!
