There are two copper oxides cupric and cuprous and it combines with other elements in the atmosphere. This can be seen with copper roofs where initially copper oxide forms, replaced by cuprous and cupric sulfide, and finally by copper carbonate. The final carbonate patina is highly resistant to corrosion. Can't remember which is which but one is black and normally means water has got into the cable and it is an insulator so makes terminating the cable hard.
Eric
