blade removal from table saw
10 Sep 2010
Staffordshire
I am struggling to remove the blade from my table saw. Just can't seem to undo the nut. I thought it would be left hand thread?
Have you tried giving the spanner it a sharp tap?
Have you also got the blade against a piece of wood to hold it firm.
Have done all of those things. I have changed it in the past but for some reason this time it just will not free up
It can be either L/H or R/H thread; you should be able to tell by looking at the end of the arbour thread poking out through the centre of the blade. It may just be tight I do the same as Diyisfun; to lock the blade I do turn the saw upside down & push the blade teeth into the top of a lump of soft wood. Using a well fitting spanner, a few sharp whacks with a hammer will usually shift it but they can be stubborn; make sure you establish which hand thread it is first though!
Finally shifted it! Copious amounts of WD40 and a bit of bad language works wonders! Thanks for your suggestions.
Bit late seeing as you have got it off but often trying to tighten the nut first works, seems to break any "bond" that has formed, works well on most fittings and screws too.
