- Joined
- 31 May 2016
- Messages
- 28,202
- Reaction score
- 7,220
- Country
With NASA cut backs and Ellon’s record on driverless cars I’m not sure I’d trust either to design a safe space craft, let alone achieve a SPOF standard.
Incorrect, as the use of pure 02 is used in medical emergencys in both a hyperbaric chambers and on the surface to treat divers that are showing signs of decompression sickness, where a diver cannot be re pressurised in a chamber then breathing pure 02 is a treatment.Case in point: pure oxygen is toxic at all pressures. However as the pressure increases the rate at which it affects you also increases. What might take days at 1 bar takes four hours at 1.3 bar.
Completely wrong, technical divers use mixed gasses as do commercial divers, you cannot breath pure 02 at depths deeper than 6 metres it would kill you. Mixed gasses that divers breathe is a mixture of 02 and helium known as Heliox, lots of other mixed gasses too.That's why technical divers can use pure O2 in some cases deeper than 6m and why you have to monitor your pressure exposure time. Or you would if anyone actually dived recreationally on pure O2.
You what? SpaceX and Musk don't build anything on the Artemis programme.
You might be trying to reference the NASA policy to have multiple launch vendors, but that's irrelevant. I have seen something like that in some companies, often law firms. It's an initially good idea but quickly ends up wrecking projects by insisting that the only services you're allowed to use are the lowest common denominator.
Artemis is a Boeing rocket not SpaceX. Musk doesn't have a look in.
Prepare now for the insults. He will claim to have been to the moon shortly.I wonder who is involved in Artemis IV
NASA Adds Mission to Artemis Lunar Program, Updates Architecture - NASA
As part of a Golden Age of exploration and discovery, NASA announced Friday the agency is increasing its cadence of missions under the Artemis program towww.nasa.gov
Looks like he does have a look in. After all.
Not in Artemis II he doesn't. Seriously are you still that ****ed off I pointed out you didn't understand your sources and couldn't do basic multiplication a month later?I wonder who is involved in Artemis IV
As predicted.Prepare now for the insults. He will claim to have been to the moon shortly.
As a diver you do know what a hyperbaric chamber is don't you?Incorrect, as the use of pure 02 is used in medical emergencys in both a hyperbaric chambers and on the surface to treat divers that are showing signs of decompression sickness, where a diver cannot be re pressurised in a chamber then breathing pure 02 is a treatment.
I refer you to what you actually said.Not in Artemis II he doesn't. Seriously are you still that ****ed off I pointed out you didn't understand your sources and couldn't do basic multiplication a month later?
Pure O2 is also used in medical procedures. I had some just a few weeks agoAs a diver you do know what a hyperbaric chamber is don't you?
And none of that contradicts what I wrote you illiterate Mordor asylum seeker.
If you couldn't work out from this that I meant the rocket that was about to launch you might want to join Goblin boy in remedial reading lessons.I refer you to what you actually said.
Artemis is the mission and Musk clearly does have a look in.
We got there.If you couldn't work out from this that I meant the rocket that was about to launch you might want to join Goblin boy in remedial reading lessons.
Wow, is it really? It's almost as if it takes days for the toxicity to do damage at RTP!Pure O2 is also used in medical procedures. I had some just a few weeks ago
Also I think that the masks deliver pure oxygen but they're designed to allow other gasses in as well to dilute it, so you are breathing a higher concentration of O2 but not pure O2.Case in point: pure oxygen is toxic at all pressures. However as the pressure increases the rate at which it affects you also increases. What might take days at 1 bar takes four hours at 1.3 bar
Not this one he doesn't. He has a part in another part of the Artemis programme, but this mission is spaceX free.We got there.
SpaxeX is involved in the Artemis mission.
AI says:We got there.
