Bleed valve replacement
12 Nov 2016
Can anyone advise if the valve in the attached picture can be replaced?
Thanks Gas2Air, would that be the large paint-spattered outer nut or the smaller, inner one around the bleed screw? Also, do you think that the replacement valve is a standard size? Thanks again.
Thanks Hugh. I guess I'll need to isolate the rad and experiment...
