bleeding air from system
mjd
10 Oct 2004
I am sure I can hear air in the CH/HW system at the pump on start up, after a time it does diminish but not go completly. I have tried bleeding all the air vents and rad's also the pump but all I get out is water.
does anyone have any ideas on what might be causing this, how to bleed the air from the system?
Mike
Sorry I thought I had given you all you need to know.
Have changed or added nothing.
It is loudest approx 5 sec after boiler start up (time taken for water to travel from boiler to pump?)
Noise goes after a couple of minutes.
boiler is an infamous Baxi Barcelona that still has times when it only works in 15 sec batches but most of the time it's ok.
thanks
Mike
Thanks for the advice regarding the boiler and yes I have all the threads on the boiler but at the moment a boiler change is not an option plus if you ask what to get to replace it with all you get told is, anything is better that that!!!! any suggestions????
Back to my original question how can you get rid of the air in the system if you cannot bleed it out of the many vents provided? or are you saying the air is caused by the boiler?
Mike
Mike! apart from bleeding radiators and pump, I found with the system stopped and a radiator removed I could run off water from each radiator valve in turn that would allow any trapped air in the circulating pipes to escape. But will removing the 'air' solve your problem. I suggest you search and read the posting by johnhump 11 Aug 2004 and the comments by ChrisR
:roll: :roll: :roll:
No prob's Kev I feel the same as you regarding the boiler :lol:
MANDATE
Thanks for info will find thread and read
Mike
