Bleeding/pressure drop
30 Jan 2005
Had a gurgling problem in an upstairs radiator. Radiator hot at bottom but a lot coller at the top. Turned boiler off and bled all radiators starting with the problem one.
I only opened the valve about half a turn - lots of hissing followed by a few drops and then closed the valve, as one should!
However, a couple of the other upstairs radiators release some air but no water expelled, even after a minutes or so and opening the valve a few more turns.
Downstairs radiators are not a problem it seems. What surprises me is that no water came out after the air hissed out of rads. System is only 2 years old.
Returned to boiler and fired up but pressure guage remains between 0 - 0.5bar and only goes to nearly 1.0 bar if the hot water tap is turned on.
The boiler is a BAXI COMBI 105E.
Gurgling upstairs rad now hot throughout and no gurgles.
Any pearls of wisdom greatly appreciated. The cheques banked and the guarantee out of time Kev!
Pressurise using filling loop to about 1.2 bar, continue to bleed all rads, re-filling as necessary, the pressure when all rads are bled should be about 1.2 bar. Turn it on, all should be OK.
Thanks artful, thanks kev. I've found the loop but not 100% sure about doing it but,here we go!
It worked, cheers guys. Makes me feel really competent, but on a scale of 0-100 I guess I'm a 1!![/img]
