The last retaining wall we built at 1m tall was (architect designed) 325mm thick at the base, reducing to 215mm. 7n blocks laid flat with a brick facing, plus weep holes, perf pipe and gravel and painted with black jack at the back. Ex-con joints every 4m I think.When building this would an expansion joint at 5 metres be sufficient? The wall will retain soil , I could add piers for support if necessary but hoping block on flat will suffice. Thanks in advance
You didn't say what heightThe wall will retain soil , I could add piers for support if necessary but hoping block on flat will suffice
Apart from the thread title?You didn't say what height
I'm the worst for only reading part of a thread or post. Guilty.You didn't say what height
