sealocrete do a product thats applied to the surface and it brings out the colour of the blocks. it also seals and protects and leaves a slight shiny finish. only apply on a dry day.
do not use it on clay paviors as it can blister off due to the clays impervious nature.
after kiln dried sanding you can apply a joint stabilizing solution that will help to keep the sand locked in.
