BLOCKAGE IN PIPES
shes not got an immersion has she. i dont think well sort this over a keyboard. you'll have to take the plunge and get someone in.
ps everyone gets worn out :lol:
so heating ok but when hot water only is selected, the boiler fires but switches off?
and there any valves (2 port etc) on the hot water flow to the cylinder or thermostats on cylinder?
annie - IS THERE ANY WATER COMING OUT OF THE HOT TAPS :?
Will the cleaner be powerful enough to clear a sludge blockage between boiler and hot water cylinder or sludge around coil in tank - I think thats what I mean!!
Sounds like you have an airlock and need to remove the boiler stat and boil the water, but seeing as how its a back boiler you really need a heating eng.
Bster
thank you there is water in taps but it is cold.There are no diverter valves in system. It is 32 years old.Only a drain cock next to pump.
Gavinda
shes got immersion heater
Pipes cold to hw cylinder going in and coming out-still think is is blockage in tank or in pipe from boiler do you think this makes sense.If you have given enough advice thaks for your helpBest wishes Anne
Without knowing how your system is configured its difficult to make any useful suggestions.
The normal solution would be to call a competent heating engineer!
You said that you have "NO VENTS". If that means no air inlet vents then thats potentially very dangerous!
All 552s and similar boilers need ventilation vents direct to the outside otherwise they can produce carbon monoxide which can kill can kill!
Tony Glazier
i saw that too ag but a even a non tech person wouldnt mention no ventilation as a poss cause of no hw.
but yeah you need eyes on help
best of luck annie
be prepared as well.. if the boilers not been looked at for a while you may find the boiler gets turned off :cry:
THANK YOU ALL FOR YOUR INPUT
YOU HAVE ALL BEEN VERY HELPFUL AND POLITE TO A NON -TECHIE LIKE ME .
JUST TRYING TO SAVE MY MUM MONE THAT SHE DOESNT HAVE. CHEERS
ANNE
annie53 said:
I have asked an Engineer to call but no one has turned up been waiting all week.
Sounds like British Gas !!!
OR
You should have called British Gas, they would have been there the same day!!!
