Hi All,
I wonder if you can give me some advice please.
I've just moved into a house 2 weeks ago, the house is 7 years old and the previous occupier turned the boiler off 6 weeks prior to me moving in. The property is a 3 storey town house.
Problem....on moving in day the heating didn't work!
The central heating system is a vented s plan with micro bore pipes. The boiler works fine as it produces hot water, it also produces hot water for the central heating but this all goes down the auto bypass pipe as there appears to be a blockage somewhere in the c/h system.
I've had the system powerflushed but this hasn't helped. The diverter to the c/h works as British Gas came out and tested it but suggested that there is a blockage or a valve somewhere in the system that has been turned off.....why someone would turn off a seemingly hidden valve I do not know! The pump is fine also.
As no single radiator receives heat , I'm inclined to think that the blockage is between the diverter and where it splits to the various legs of the heating system. Do you think this assumption is correct? And if so should drain the system, remove the diverter and pour some cleaning chemicals down in an effort to loosen up expected blockage?
Also so you think that there might be a hidden valve somewhere as the British Gas guy suggests, I cant see any.
Thanks for reading....any advice greatly appreciated!
