Hey I'm after some advice. I've got a blocked sink/pipes and I have no idea what to do (I'm a student living in my first home away from home lol).
So the sinks blocked, no water will go down it. I took a plunger to it only to find that when I plunge, water then comes out of the hole above the plug hole kind of in between the taps. I tried blocking the hole with a tea towel and plunging again. This seems to have lead to more problems because when I did that, I could hear water leaking out from under the sink.
I then disconnected the white pipes under the sink which connect the bottom of the sink to the pipe which I assume goes outside. I disconnected the U bend bit, which had water in which I tipped out. There was no sign of anything which may have blocked it though.
Once all of the water was drained from the sink through the disconnected pipe and into my bucket, I reconnected the pipe and tried to run the water. It went right down the plug hole as it normally would but after 10 seconds or so the sink became block again and the same leak happened from under the sink.
The leak is quite a big drip and it’s on the bottom of the sink it's self, where the sink connects to the pipes. It's not on the pipes; it’s on the seal around the bottom of the sink which connects the sink to the pipes. I’ve tried plugging the leak, but it’s too strong.
Can anyone suggest anything?
