Hello all,
I would like to block holes in the walls around some of the areas in my house. For example the holes where my boiler exhaust pipe leaves the house and toilet pipes. I mean all around the pipes where the builders have made holes in the walls.
What is the easiest and most cost effective way to do this? Bearing in mind some of the the holes are quite tricky the get to due to obstructions of units.
I have some "postfix" in the garage will this be ok for the job? Is there any foams I could use that would offer a gas tight seal?
