Hi I need to block 3 chimneys as they are letting in enormous amounts of cold air. The 4th I am using for a proper wood burner.
The 3 chimneys I am not using I was going to block with a paper mache...
Is there a risk of fire ?
I understood that each chimney has its one whole so there is no way a spark can go up one chimney and down another.
Would appreciate some assistance..or advice.
To block it I was going to use the newspaper add some water and some wallpaper paste and create a mache and stuff it up the hole. All the chimneys have proper fireplaces (but not burners)...and have not been used.
The house is a 30's semi detatched.
Thank you
Thank you
