I have an underfloor heating mat that has been down for 8 years laid on a insulated concrete floor and under tiles in the hall. It was checked with a multi meter before and after installation.
It has worked perfectly all that time but yesterday it blew the 13a fuse on the switched fused spur.
I replaced the fuse and it switched on and started working then after about half an hour it blew the fuse again. Because the fuse holder cracked when getting the blown fuse out I have put a new fused spur on and again the fuse has blown after about 20 minutes or so.
The floor hasn't been damaged or the electrics disturbed in any way, no water has got into the electrics or under the floor.
I have checked the wiring into the fused spur and from there to the thermostat and everything is nice and tight and no signs of overheating or anything.
I can get access to where the tails go into the floor but don't want to rip the skirting board off just yet.
Has anyone any ideas where to go from here ? any help would be appreciated.
thanks.
thanks.
