Hello all, Im new here and not great at DIY so after a little advice on a problem.
We have a Glow Worm 24ci boiler at home. My first issue is when the heating is off the boiler will lose pressure and stop working until I re pressure rise it. (drops from around 1.2 to 0.6 normally in 8-9 hours) I have checked heaters for leaks and cant see and nor do we have any wet patches on the floors etc.
Second is when the heating is on the noise from the pipes is getting louder! Could this just be do to with air in the system? It is worse when the heating is first put on but does continue most of the time. It now sounds like its coming from both bedrooms and the bathroom.
If anyone needs more info I will try to help.
Thanks in advance
David
Thanks in advance
David
