Boiler Apps
4 Oct 2022
Hi
I have an Ideal LOGIC 24 kw COMBI boiler with Center RF Wireless Room Thermostat is there a way of controling the boiler with a smart phone app.
Advice would be most appreciated.
You can use Ideal's own 'Halo' device/system or the Nest or Hive smart thermostats
Moes seems around the cheapest wall thermostat with wifi, but what do you want to control.
For myself when we go out for the heating to switch off, and then switch on again when we approach home switch on again would save fuel, and no need for it to be a thermostat, it could be simple on/off. Called geofencing.
However I just use a smart socket adaptor to switch my AC on/off so could use a sonoff switch without any temperature control.
What do you want it for?
Hi thanks for your reply.
I am away from home quite a lot and I thought it would be handy to monitor temperatures and turn the heating on if required.
Hi
Just ordered a Hive mini thermostat with receiver and hub.
Thermostat arrived today, from start to finish took 10 minutes to install and set up.
