Boiler change
9 Dec 2017
Hi had a plumber yesterday because I have two cold radiators and one luke warm one he did all usual checks checked thermostats and made sure valves was fully open but no joy.. He said the system I had was self pressurised and this was a common fault due to contamination in pipes causing a blockage, he said it would require a power flush and a metallic filter fitting he said although this should cure the problem it was not guaranteed and a blockage could occur at any time.. So as my system is 13 years old he says it may be more cost effective to have a new boiler fitted just wondering what people’s thoughts are?
Well if you have a new boiler fitted and the contamination is still in the pipes then the new boiler will soon suffer the same blockage. A new boiler would ( should ) be fitted after a power flush. So have the power flush and if the old boiler is then able to warm all the rads keep it until it really needs replacing.
It would help to know which boiler you have and what shape it's in.
Some boilers last well beyond the oft-quoted average of 15 years, others not!
What your man suggested is not unreasonable IMO.
Installing a new boiler will have no affect on blocked pipework or rads in so far as just putting a new boiler on wont clear out the pipework. He needs to confirm if it is the pipework or if another part of the central heating system is causing it.
If it is blocked pipework then flushing/cleaning it out can bring it back and there may be noting wrong with the boiler. I wouldn't be recommending a new boiler until the old one is definitely identified as the cause.
It certainly wouldn't be the most cost effective approach, if there is nothing wrong with the boiler.
If pipes are furred up, how is a new boiler going to fix the problem.
If a pothole on your drive was damaging your car, would you...
a) buy a new car
b) fix the pothole?
Your man is suggesting that you ignore the pothole and buy a new car
