Boiler constantly fires - strange Y/S plan hybrid??
22 Apr 2015
Surrey
My boiler is firing whether the programmer is on or off. There is no stat in the house as far as I can see. The programmer has been replaced, didn't make any difference, the heating is still constantly on.
Having looked at the controls there is a 3 port valve, which then leads into a 2 port valve on the HW side. The heating side of the 3 port Ts off, one way to downstairs but then one way to another 2 port valve on the pipe.
Pretty confused as to what's going on. Sure it's a wiring fault but the electrician won't do anything until I figure out if it's Y plan or S plan, and to me it seems a strange combination of the two. No idea what the two 2 port valves are doing on the system, they seem redundant.
Any help would be great pease!
Hopefully some of the more experienced guys on here can offer some better insight, but, for me it sounds like you have two extra 2 port valves on a Y-plan. Not sure why you would need them though if the three port is functioning correctly.
Have you got a diagram of yourfull system?
More info required. Cylinder type, boiler make/model, maybe a photo of the valves etc in airing cupboard. It may well be one of the valves telling the boiler to fire.
The boiler is one of those little compact Pottertons, Envoy i think. Not sure on the cylinder.
BC:Are you the householder, or a plumber? If the former, them the sparks, if he is being paid, ought to help identify. He should be able to identify what is switching what.
Maybe it is a DIY install, the 3 port being operated by the programmer, the 2 port being operated by the cylinder stat. Can't imagine why, but then, I can't imagine why there is a 2 & a 3 port.
The heating on all the time is probably a stuck on micro switch on 2 port.
Thanks Fireman, yes he should but I think he's in the dark as much as I am and has no idea what's going on.
I don't know if it's a DIYer but the people in the house previously lived with the heating on for 2 years and just opened the windows as a solution instead of getting it fixed.
Nope. Conventional set up, only differneces are a recirculating HW pump and then the suspect port valves.
Can't i'm afraid, no longer at the house. Was just hoping someone had come across this before.
I'd imagine one of those zone valves has a sticky microswitch, dont need a sparky just a heating engineer with a multimeter.
