Hi, I could really do with some help!
I have a Gem combi boiler, which I'm guessing is about 12 years old or so. I don't know anything about the history of the boiler, because I just moved into the flat. I'm aware that Gem boilers aren't very commonplace.
The boiler was playing up a bit from when we first moved in, e.g. the overheat reset light coming on fairly often. The timer wasn't working properly - clock was ticking round, but the segments weren't clicking to turn the boiler on. Also, sometimes the hot water wasn't very hot - hot enough, but not very hot.
Anyway, today I decided to bleed the radiators. I then topped up the water pressure to just above 1 bar. When i turned the boiler back on, the overheat reset button kept coming on, with quite a lot of noise. I managed to get it to fire up for a while, but it went off again after a few seconds, with a very slight smell - possibly electrical. Now it's completely dead - it does absolutely nothing when I turn on the heating or the water. I checked the fuse in the plug, which is fine. In fact, I can still hear the clock ticking round.
Has anyone got any idea what could be wrong? The pump? Some of the electrics? I'd like to get a rough idea of possibilities, so I can figure out whether it will be cheaper to get a local plumber round (I've found one on gumtree at £35/hr) & pay for parts, or to go for the £156 flat fee from British Gas. The cheapest place for Gem parts that I've found is here... http://www.europeanspares.com/index.cgi?command=list&pos=24&visit=1196963986-12222 The timer alone is £63, which is more expensive than other brands of boilers.
Eagerly awaiting your advice...
