Hi all, I have an Ideal isar HE30 boiler which keeps switching itself off with LF fault. I have already replaced the flame detection electrode and spark generator assembly with no luck so far, it's not overheating either. It's now making quite loud banging noises at certain times (not in connection with any of its actions for example when the hot water tap is switched on). It will run fine for a length of time but then switches off and the LF fault comes up. Any advice would greatfully be received at mother in law coming for xmas!!!
Grayman.
An update on my problem, I've now discovered that the fault occurs when the display tap comes on for the boiler to fire up to periodically pre heat the plate heat exchanger. The boiler makes a rumbling noise and the boiler shuts down with the LF sign. Please help if any one knows what this might suggest.
