Hello,
I have an Ideal Isar m30100 which cuts out with error code LF whenever a hot tap is turned off.
A week ago a boiler engineer replaced the flame detection electrode but the problem remains.
The central heating is functioning ok, and when the DHW is running plenty of hot water flows from the hot tap.
When the hot tap is turned off the display goes from d with steady green LED to d with flashing green LED.
After 10 flashes there is a click and then the display shows LF.
On pressing the reset button the boiler fires up and will again supply central heating water and DHW.....until a hot tap is used and then switched off....which causes the cut out again.
The cut out also occurs during the night when the c/h is off. I have not observed it directly when it happens, but I think this will be the preheat which, on reaching the desired temperature, switches off the gas in the same way as turning off the tap. I am not an expert, I am surmising this to be the case, and I may be wrong about the reason for the night time cut out.
If anyone can shed any light on this fault we would be very grateful.
Thank you,
member Sun Dial
Thank you,
member Sun Dial
