I've just had my boiler replaced with an Icos HE18. However, since it was installed 10 days ago it works normally for a while, then for no obvious reasons fires up even thought the timer is set for it to be off and the lights showing active CH or HW are off. Most times I can turn it off by lowering the setting on the thermostat but sometimes that doesn’t work either - maybe its trying to heat the hot water but I'm not sure. It tends to work fine for a day or so then does this in the middle of the night. The installer cannot find anything wrong and replaced the timer but it still goes wrong. If the timer is physically removed and left aside for about half an hour it all goes back to normal. We never had that problem with the 23 year old Baxi boiler.
