I have a 2-3 year old combi boiler called a Procombi HE, the vapour from the flue is going across my neighbours property and they have complained is it possible to purchase a flue that could take the vapours upward by about 3-5 metres.
Depends on which boiler, but can be between 2.85 and 8.8 metres. Using an 80/125 flue and you can go up to 25m. See Pro-combi literatureI doubt that you can extend the flue with a plume diverter kit for as long as that, it could well compromise the working of your boiler.
SecondedThis is certainly not a diy job.
I don't install baxi's nor do I intend to change that, so I have not looked into their specifications, but somehow I doubt that you can use a 25 metre plume diverter on them.Depends on which boiler, but can be between 2.85 and 8.8 metres. Using an 80/125 flue and you can go up to 25m.I doubt that you can extend the flue with a plume diverter kit for as long as that, it could well compromise the working of your boiler.
Really? See Pro-combi literature Page 6.Nothing in the MI about the length of plume diverter permitted.
Agree it's not a diy job. The literature for these boilers via the link indicate up to 5 or so metres vertical is allowed.I doubt that you can extend the flue with a plume diverter kit for as long as that, it could well compromise the working of your boiler. This is certainly not a diy job.
A better solution than such a length would be a shorter one with a directed outlet pointing away from the neighbours.
Both Band A and Band B models are called Procombi HE, so it's not clear which one the OP has. In any case the table on page 6 gives flue lengths for both bands and I was careful to cover both bands in my post.Whilst I appreciate that as you dont work on boilers you can be easily confused, you have chosen a DIFFERENT model of boiler than the OP has fitted.
Your MI refers to the Band A premix model.
