Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Gas Safe engineer needs to hang the boiler on the wall to satisfy themselves that the fixings are good - they're taking responsibility, after all. Could always get them to do that and the flue in one visit, then connect the gas and commission the boiler once the wet side is done. Whether you can find anyone actually interested in doing that is a different matter. Who would take responsibility if the boiler failed at a later date due to system debris, for example? Technically that's on the installer too, as they have to sign the benchmark to say that the system has been correctly flushed and protected.
As mentioned you will struggle to find gas engineers happy to sign off a boiler where a lot of the work was not done by them and rightly so as on paper they are responsible.
So if I just leave the pipework next to the boiler and get them to fit the boiler and connect up then commission the system there should be no problem with that, all good
