- Joined
- 22 Oct 2015
- Messages
- 29
- Reaction score
- 0
- Country
In July we had our open vented back boiler break down so replaced it with a sealed condensing boiler. 2 radiators were replaced too but the remainder and pipes are the original ones.
Before the replacement we had air often collecting in our highest radiator, the bathroom towel rail. We were told this was most likely due to the pump sucking air in and collecting in the highest, and first, radiator in the system.
Our problem is that it seems to be still happening. The system is pressured to 1.5 bar and rises to a bit under 2 bar when heating. If I bleed the towel rail and pressure the system then over the next week the top rung gradually gets cooler but the boiler pressure doesn't seem to drop.
Over the summer I bled the towel rail regularly, despite not having the heating on, and got air out and the pressure dropped from about 1.3/1.4 bar that the system was originally pressured at to just above 1 bar. I am not certain but I believe that the pressure only went down when I bled.
I have tried bleeding the towel rail and then again about 6 hours later, without the heating having been on, and I get a small amount of air.
I pressured the system on Saturday morning while cold and I am avoiding bleeding to check whether the pressure does drop. So far it doesn't appear to have dropped. The rail is still warm but much cooler than it was on Saturday and cooler than the other rails. I can hold the middle of the top rail comfortably but I cannot touch the other rails, nor the edges of the rail for long.
I contacted the plumber and they said that if air is getting in then water is getting out and we must have a leak. They told us to go round all of the exposed pipework with coloured paper towels to see if I can find anything but I couldn't. Their response to me saying this was that it must be in the pipework but that it would be 'like looking for a needle in a haystack' to find. They recommended waiting for it to become more obvious.
I have spoken to other people who think it is an airlock or air getting released from the water that filled the system and will settle down. They say that the pressure would change on the boiler if it were leaking. They also question air getting into a pressurised system.
I'm not sure what to believe. I think it is probable that we have a small leak that we've had for a long time and now it's getting noticed.
Our piping is mostly within our first floor and it drops down to the radiators on the ground floor from the ceiling. I can only find one place where it goes through a wall.
I'm just not sure of what my next steps are to fix this. I've looked at getting hold of leak specialists to help but these aren't cheap. I could also contact my insurance but I'm not sure I really want to claim.
What should I be doing to fix the leak?
