got a glowworm compact 80 combi boiler had a new fan fitted last week now when the heating been on for a while the boiler is making a loud rattling noise but its intermitent any ideas what it could be before i ring bg up again many thnxs
are you sure you have'nt got air trapped in the pump - best way is to slightly undo the slotted srew in the middle of the pump - if air is trapped it will escape - do this till no air is noticed - tighten up and fill the boiler again.
we have 2 pipes that run straight down the side of the boiler and into the kitchen these has started to make a vibrating noise when the boiler is heating up now and again can this be caused by the casing rattling as they do touch the boiler slightly
