Hi There,
First post here, so please be gentle....
Anyway, my house has a Grant Eurotherm oil fired central heating boiler running an open vented system with a single hot water tank and 12 rads.
Recently though, it has started taking an extremely long time to heat the water in the hot water tank for a bath - over 3 hours! And even then, we're not getting the same amount of hot water or the same temperature that used to.
The hot water tanks also has an immersion heater, and that heats the water in about an hour, but obviously the electricity cost is more than the oil.
The boiler itself seems to be fine and was serviced about three months ago, when it had new baffles fitted. It comes on fine on the timeswitch, fires up and sounds like it's heating the water, but a mentioned, it takes forever. If we put it on at 4pm, often there's not enough water for a bath for the kids at 7pm! The tank itself is only about five feet away from the boiler.
Any idea what could be causing this problem and how I can test and then fix it?
Thanks,
Alasdair
Thanks,
Alasdair
