Hi all,
We bought our property nearly a month ago and inherited a Heatline Vizo which had apparently been serviced a year ago.
Since we've moved in we've had no problem with the boiler/central heating/hot water. Everything seemed to be working swimmingly...until this morning.
We came down to find nothing working. There was a light flashing on the dash board and after a bit of reading we realised this was indicating low pressure. The pressure gauge was at 1 so we added pressure until it was 1.5. This made the indicator light switch off and we thought we had rectified the problem, but we can't seem to get the boiler to ignite again. According to the Heatline instructions you reset the boiler and it should reignite but nothing.
Can anyone shed any light? Are we being really silly first time buyers and missing an obvious 'ignite' switch on the boiler?
One more thing, when trying to fix the problem some more my boyfriend managed to up the pressure some more to 2 (cold). I know this is too high and went around bleeding the radiators in an attempt to release some pressure but it hasnt seemed to work. Has he caused an additional problem?
Thanks in advance.
anahavana
Thanks in advance.
anahavana
