Hi
I have had a Potterton Kingfisher MK2 RS60 boiler installed for the last 13 years. It supplies pumped CH and gravity DHW. It has never gone wrong and is still working faultlessly.
However, I was recently cleaning inside the casing and looking at the flow & return pipes noticed that they were not as the connection guide in the manual. i.e. The DHW connections were both on the LHS. The CH pumped return is on the RHS with the flow on the LHS. The manual shows flow for DHW may be either LHS or RHS with the return on the RHS and pumped CH flow and return both on the LHS.
As the system has been working "correctly" for a number of years can i assume that this configuration is acceptable.
