Boiler plume problems
20 Jan 2021
My neighbours boiler plume is kicked out their flue next to my daughter's bedroom window and is causing damp to build in the corner of the room. I have asked them to put extension on but wont they say it's legal distance (they're correct).
Is there any sort of product I could mount on our boundary to deflect the plume. Or is a sheet/plate just as good
Do you know it’s definitely the boiler plumage causing this?
Get a close up of the flue terminal - it may have an end piece that can be re-mounted to point L R U or D.
sorry to hijack, but my query is quite similar: I need my boiler outlet pipe to be extended up then out, as the plume is making my own fascias green. What do I search for for a solution?
Is the first one on this page the jobby I'm after? It says it should be installed by a gas installer - isnt it just a matter of attaching it ??!?
I was of the impression that while there is a set of minimum distances specified in Building Regs and manufacturers instructions for the placement of the flue terminal, that there is also a catch all that says the plume from the flue must not cause a nuisance.
No, fitting it can affect combustion as you're extending the exhaust, and also creating a difference in length (and therfore resistance) between the air intake and the exhaust. The boiler will need testing with a flue gas analyser and the gas valve may require adjustment
