Boiler Pressure Dropped
16 May 2014
Aberdeenshire
Hi
I recently removed a radiator in my living room to decorate. I refitted it, bled it and topped up the boiler pressure. 2 weeks passed and the pressure had dropped below 1 bar and triggered an error code so the boiler wouldnt fire up. I checked everywhere and no leaks. I topped up the pressure and the boiler fired up. Could this have just been a spurious air bubble working its way up?
Cracked heat exchanger will cause a drop in pressure and you won't see anything.
Just monitor and if pressure drops you could have a problem
Hi
No, air bubble is under the same pressure as the water it is contained in, where it is located or moves to makes no difference
