Boiler pressure loss through condensate pipe?
  • Thread starter Thread starter gtg
  • Start date Start date
I wouldn't use dye, you can use inhibitor and its associated inhibitor test kit to test the condensate water, but to buy both would be starting to rack up the price a bit
I don’t think any solution will be cheap at this point so I’m willing to give it a try!
PH test could also work. We’ve got a PH test kit from setting up our fish tank so may be worth a shot.
I looked into the fixed price repair but it doesn’t cover heat exchanger unfortunately.
Get some food colouring or even drain tracing dye, if you could introduce it in to a towel rad by isolating it, draining off some of the water inside. Unscrew a cap use a funnel put it all back together, fill, bleed open lockshields.........you'll see the colour in the condensate if the heat exchanger has gone.
The dye won't hurt anything but at least you'd know for sure.
