Be interesting to see what or indeed if the response will be.
Ironically I would like to hear the correct answer.
See link below to relevant legislation on gas safety.
Bear in mind also all work on the gas side was carried out by a registered Corgi engineer.
However much you might want it to be otherwise nothing in the regulations requires you to be registered with CORGI or HSE to work on a heating system -even on the gas side. The exception is when you are doing work for gain.
http://www.opsi.gov.uk/si/si1998/98245102.htm#3[/QUOTE]
in itself, IF you are competent, you can work on gas without being corgi registered.
however, it IS illegal to certify a boiler as being installed by a RGI when it is in fact installed by a diy-er. and as we all know, employing someone to commit an offense is an offense as well.
you are at least number 714 in the past 12 months who thought he is clever, but it is very clearcut.
what you have done is illegal, can be prosecuted, both yourself and the cowboy who signed it off.
not sure about vaillant, but wb uses a jig that connects all pipes and the actual boiler is set on top of it. at least for the combis
So, if and when you sell the house, you aren't going to gain the difference in price between a house without a system and one that has? So you are going to remove the one you put in and have an installer replace it?
and what is wrong with the InterCombi?
Don't let that numbnut prejudice you. They p**s all over most of the mainstream rubbish that are out there - I have seem the production line and met the inventor.
there are several boiler makes out there that vary from not bad to very good. but what do you do when you need a spare and there is only 1 company in the country that sells them?
i have looked at several alternatives for wb as they are very expensive, but so far have found no product that has a good quality, AND a reliable back up.
